all my fans r working and cd drive works but i can't boot up into bias even diplay on 2 diff monitors don't work. i am using gskill 800mhz ram and x1900xt
Did you plug in the 8 pin power connector to the board? Also check the stand-offs, the board maybe grounded. I'm not sure with the ram but try a different one, maybe your gskill wont boot at the default 1.8v
Sounds like memory issue, under ide connector there is a sticker with bios version. If you have early version might not work until it is flashed to newer or you may need to get to bios and adjust memory votlage. Anyways you might try other memory.
Try one stick of ram in.
If it works, go into bios, raise the voltage up to 2.1, turn off computer, pull power cord, put the other stick of ram in, put power cord back in,and restart..
