- Aug 15, 2011
- Heidelberg, Germany
How to prevent i7-2600K to drop to 1600MHz?
Hello,i bought a ASUS P8P67pro MoBo half a year ago and have problems ever since with it. The MB is using Turbo Technology to give a higher performance but it doesnt work on some MP-Games and the CPU always drops to energysaving "1600MHz" due to my MB doesnt realize that heavy load is needed. !! in Multiplayer game !!
So i want to set my CPU at least to the desired 3,4GHz permanent, disabling every energysaving option in BIOS and Win7 64.
I ve tryed hundreds of settings, restart my PC over a thousend times in last half year, read hundreds of posts using every guide i found... nothing worked even setting the CPU to lower Frequency then 3.3GHz pushing V Core and PLL V up and so on.
ASUS Suite is only useful if u use TURBO Mode . CPU always drops down to 1600 MHz wether ingame or not.
I ve disabled Turbo Mode and Intel Speedstep, changed MB onboard TPU switch, disabled EPU onboard and in BIOS to get at least a permanent 3,3 GHz CPU without Turbo Mode (doesnt work anyway). I dont care about energy saving options and i dont want TURBO mode, i just want the 3,4 GHZ CPU i bought. Maybe someone here can help.
current settings
LOAD LINE CALIBRATION - HIGH
VRM FREQUENCY - 400Hz
PHASE CONTROL - EXTREME
DUTY CONTROL - EXTREME
CPU CURRENT CAPABILITY - 110 %
CPU BASE CLOCK - 100MHz
CPU VOLTAGE - MANAUL 1.3 V
VCCSA VOLTAGE - 1.12500 V
CPU PLL VOLTAGE - 1.81250 V
TPU MB SWITCH - ENABLE
XMP - ENABLE (8GB Corsair Vengeance Kit)
Int PLL OVERVOLTAGE - ENABLE
EXECUTE DISABLE BIT - ENABLE
INTEL VIRTUALIZATION TECHNOLOGY - ENABLE
LIMIT CPUiD MAX - DISABLE
EPU - DISABLE (MB Switch too)
C1E SUPPORT - DISABLE
SPREAD SPECTRUM - DISBALE
Speedstep Option and Turbo mode in Advanced BIOS Menu set to on and off makes no difference even Minimum Core to 3.3GHz
CPU Range set to by per core, all cores, single core -> no effect
Energy CPU Options in WIN7 are set to 100% min and max load
tried all available BIOS updates running the latest available now
There s something i missed out pls help
With regards.. CLOSETONERVOUSBREAKDOWN
current settings
