Shorting your components is not the worry. Zapping them with static discharges (ESD) from your fingertips is the big concern. You can torch a Grand Canyon sized trench (microscopically speaking) through 1000s or even millions of transistor gates in a CPU without you (as a human being) even being aware a static discharge occurred. That is, the "spark" can be so tiny, you, as a human, cannot see it, hear it, or feel it - yet the spark can still easily destroy the component.
That's why ESD is so mysterious. We may think a mishap never occurred, but if we encounter a dead component (processor, RAM stick, motherboard, graphics card, etc.) that is dead for no apparent reason, it could easily have been due to mishandling and improper ESD precautions.
No carpet is a big help but destructive charges can build up by just squirming in our chairs. This is particularly true in dry environments. And remember, it is the ambient (room) environment we are talking about here - not the outdoors environment. If you live in the humid Florida Everglades that does not matter if the air conditioning (or furnace) in your home dries out the air - which it does!
I don't wear an anti-static wristband, but I always take ESD prevention precautions by ALWAYS touching bare metal of the case interior before reaching in and before touching any ESD sensitive device. And I never touch the electrical contacts of the RAM sticks, processors, boards, or pads on sockets.
Wrap it in the static free material that motherboards and video cards are shipped in.
"In" is the critical word there.
It should be noted that those anti-static bags circuit boards come in and the plastic containers CPUs and RAM come are layered. And the outer layers are
highly conductive and you should NEVER EVER lay your components on the outer surfaces of those bags. That layer is specifically designed to "shunt" any static around and away from the device inside - like the outer "skin" of your car body during a lightning storm.
The inner layers of those bags are non-conductive. So if you are going to use them, cut open the bag and use that surface.
A better idea, however, is an
unfinished wooden bread or cutting board, or a sheet of
plain cardboard.
Do NOT use a motherboard box. The problem with "some" motherboard boxes is the printer's ink used to print the product graphics and labeling on those boxes. The chemicals and ingredients to make the various colors can consist of all sorts of things - including
metals in the printer ink. These metals (and other components in the inks), besides often being toxic, may be conductive too. Yellows and red often contain lead - not the best conductor, but a conductor just the same.
If you want to use your motherboard box, open it up and use only the unfinished interior surfaces.
