- Jan 20, 2002
Im painting my case
Primer im using equipment grey
top coat is Silver alluminum
with a clear coat
All same brand
I've done the sanding, the primer (3) coats....4 coats of top coat all sanding between coats..600-1000 grit
24 Hrs between coats ....its 70F+ here in the midwest.
My problem is when i put on my clear coat ....it turns my Silver alluminum dull and crappy. Ive tryed it with and without sanding before the clearcoat.
Any help why it is giving me headaches????
One thing i have learned (started at a new job where we make satellite dishes) that i can bake the pieces in my oven on warm or lowest setting after my primer coat has set up for a couple of hours to help harden the primer)
with a clear coat
All same brand
