Palit RTX 3090 GamingPro OC crashes
soundhunter
Hi everyone.
I've recently bought Palit RTX 3090 GamingPro OC.
There were no problems in blender or keyshot, but there are crashes in games.
What I've seen so far
deus ex md - crashes without any error every several hours.
control - crashes after 10 minutes in dx12 and I can play a bit longer with dx11. there was also bsod
crysis remastered - same as control - crashes in 10-15 minutes
furmark - 11 minutes and bsod again
there were no problems with the old gpu.
The question is - should I return it or could it be something else?
rig
asus tuf x299 mark 1
i7 7800x
g skill 32 GB 16+16
seasonic prime platinum 850
samsung Evo plus 1gb + 2gb
bluescreenview logs
Dump File : 101720-19125-01.dmp
Crash Time : 10/17/2020 23:25:21 PM
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 00000000`00041792
Parameter 2 : ffff8480`00351c00
Parameter 3 : 46000000`05001000
Parameter 4 : 00000000`00000000
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+1c2ce0
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 10.0.18362.1139 (WinBuild.160101.0800)
Processor : x64
Crash Address : ntoskrnl.exe+1c2ce0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\101720-19125-01.dmp
Processors Count : 12
Major Version : 15
Minor Version : 18362
Dump File Size : 1,016,356
Dump File Time : 10/17/2020 23:26:56 PM
Dump File : 101820-18984-01.dmp
Crash Time : 10/18/2020 2:00:11 AM
Bug Check String : SYSTEM_SERVICE_EXCEPTION
Bug Check Code : 0x0000003b
Parameter 1 : 00000000`c000001d
Parameter 2 : fffff801`7e2f77cb
Parameter 3 : ffff8085`14e962c0
Caused By Driver : Ntfs.sys
Caused By Address : Ntfs.sys+1063fb
File Description : NT File System Driver
File Version : 10.0.18362.1 (WinBuild.160101.0800)
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\101820-18984-01.dmp
Major Version : 15
Dump File Size : 1,392,084
Dump File Time : 10/18/2020 2:05:10 AM
A bug check code of 1a usually indicates a problem with RAM.
I checked ram. No problems. Also everything was ok before the new gpu
upd. I've checked gpu clock log. the max number was 2100 MHz while boost clock should be 1725 MHz
Does anyone know if the 3090 cards have the same crashing problem as the 3080 cards when going over 2000? I know the newest driver fixed it for some people but maybe you are hitting that limit if so. If not I would usually blame a power supply for crashes after a big upgrade like adding a 3090.
If I understand correctly - it shouldn't go higher than 1725. Then that's the reason. I just don't know what to do with that information yet. Try to downclock or return it I guess.
As for the 3080, I think it's the same case.
I have had absolutely no crashing problems with my Zotac RTX 3090 Trinity. Even with a hacked raised power limit VBIOS it's fine, unless I overclock it too high. On the latest drivers.
It gets to ~2100mhz.
The OP possibly knocked the RAM loose, for the "MEMORY_MANAGEMENT" BSOD.
For the other BSODs, check the PSU and drive connections!
upd
I've contacted palit a week ago. They suggested to update gpu and mb bios. Since then there were no problems whatsoever.
The weird thing is that gpu bios update only changes how fans work. So it was about temperature. But all the time temperature wasn't higher then 80°C. Maybe I'm missing something here.
upd
Yeah... Stop digging for answers and enjoy the LUCK. :beer:
