- Nov 12, 2002
- Rootstown, OH
So I have 4 of these, which I used to use with LN2 to keep parts of the motherboard from freezing over... They include a 4 pin molex for power that connects directly to the PSU, but they also have a separate lead for RPM sensing which goes to the mobo header.
I've never used anything to control my fans - I either used quiet ones, or I let them roar. Now I'd like to repurpose these Panaflo's, but they can be heard upstairs when running in the living room... If I use my Mobo's features to limit fan speed, will that work with this RPM sensor? Or does the sensor only report RPM, and not enable any fan speed control?
Essentially, I'm not sure if I understand the basics of fan speed control. I think it works like this - if you have a normal 3 pin plug that goes to the mobo fan header, the yellow wire is the sensor wire, which tells the mobo how fast the fan is going then the mobo moderates how much voltage it gives the fan to control its speed. If you have a 4 pin plug that goes to the mobo fan header, it's a PWM fan and its speed is controlled through signaling in the motor.
Thanks for any input. If I'm on track with the basics, I'll probably just do a 5V mod and see how that works for me.
