But if the T-line is not capped, the placement of the T-Line relative to the other parts of the loop determines if the water will flow out of the T-Line until their isn't enough water to reach the pump, or gravity has pulled all the water to a level equal to the T-Line openning. Also, in the cases that the fluid doesn't leave the loop, as soon as the pump is turned off then the water will suddenly leave the loop, as the pump isn't drawing in anymore water.
That is incorrect.
I've got rigs running right now with T-line ends well below the top point of the loop. There is no air in the lines above the T-line and water does NOT come bubbling out the top of the T-line. No, the T-line is
not sealed well enough to hold water against gravity. No, the pump does
not need to be turned on. In fact when I filled it and was bleeding the system it wasn't capped at all - and no water was coming out the top. Nor does water come out the top when I (very rarely) turn the system off for maintenance.* As I explained earlier a closed loop is essentially "flat" as far as relative height goes and
as long as the open end of the T-line is pointed up it is "above" the rest of the loop regardless of the actual 3-D location of that loop.
From your apparent mis-understanding of how a single T-line in a closed loop works you now know why it might have been difficult for me to wrap my head around the idea that the T-line end does not have to be above the top point of the loop nor does it need to be sealed to stop water from coming out of it. I was told this by someone on these forums back in June '06 when I was putting together my first loop and I ran experiments to prove it to myself because I couldn't believe it either - now I'm a believer. (Cut to
I'm A Believer written by Neil Diamond and performed by
The Monkey's, 1966.
The T-line should have some type of dust prevention on top to keep the loop from getting contaminated. It can be "sealed" if desired but it's not necessary. One of my loops is more or less "sealed" because I got fancy with it and bought a fill-port but the others aren't.
PS
*It should be noted that there is a
very small rise in the water level when the pump is turned off. It's no more than maybe 1/4" (when the system was new) and is caused from contraction of thin-walled tubing when the pressure is decreased. If one were to "top off" the T while the pump is running there might be some spillage when the pump is turned off. The change in water level should be minimal when using thick-walled tubing but all I've ever used inside the case is thin-walled 1/2" Tygon with SmartCoils so I can't say what change there might be - only that it will be less or equal to ~1/4" ...
