I have a new setup and my ram wont run the speed its rated for. I have a gigabyte 990fxa-ud3 (rev3) running an amd fx 6300 am3+ with my Patriot viper 3 black mamba 1866 ram.
from what i have read so many people do infact get 1866 with my board and cpu, but im beginning to think its only capable of doing so with only 2 dimms of ram (im running 4 4gb sticks @1600)
every time i try and set the bios to run it at 1866 via adjusting the memory multiplier or timings or if i enable XMP it fails to boot and resets to previous setting. I can run the ram with its timings (stated on ram) without fail so long as i stay at 1600mhz, i could try to remove 2 dimms and see if i get my 1866mhz but my giant heatsink and fans make that difficult.
after further investigating the specs for my motherboard state it will only support memory speeds faster than 1600mhz with only 1 dimm per channel WITH the AM3 series processor, so with a processor upgrade i could achieve my 1866mhz?, I'm trying to get the most out of my board but i believe the am3 processors are the best i can equip with it?
any input would be greatly appreciated, at the moment it would seem that the only boost past 1600mhz would be through my FSB, and i plan to overclock with my cpu multiplier, i seen some people with my processor run 4ghz+ stable with my 3.5ghz cpu
