Today I have Patriot Viper 4 2x4GB DDR4-3200 CL16 memory kit. I'm not often presenting Patriot kits and it's actually my 2nd DDR4 kit from this manufacturer. Not so long time ago I had a chance to test Patriot Viper Elite 2x4GB DDR4-2800 CL16 which is probably on similar IC as Viper 4 3200. We will see that in tests.
As usual photos will be added later.
Here is link to the product page.
Patriot Viper 4 DDR4-3200 memory has 1 XMP profile - 3200 16-16-16 1.35V which works good on ASRock Z170 OC Formula ( as you can see below ).
and couple of tests at XMP settings
As you can see, tests were made using i3 6320 CPU as 6700K is busy in other rig. It doesn't change fact that results are pretty good for XMP settings.
some more tests will be added later ...
