- Jun 16, 2003
- Cranberry Twp. PA
Okay, I got my XL, as you can see in my other thread. I got my VF700-C Zalman cooler. I'm all set. I'm not going to post benches 'cause I want to find the max clock on this card. I would like some help along the way here, encouragement, etc. We can share laughs, crys, and beef jerkey.
Anyway....
My card: Teh Powercolor x800xl VIVO
My cooler: Zalman VF700-CU
Default vgpu: 1.35
Default core: 400mhz
Default mem: 397mhz
So far, using ATI Tray Tool to find max values I get...
Core / Mem
400 / 490 : stock
440 / 490 : max core
400 / 592 : max mem
440 / 537 : max core then max mem
423 / 592 : max mem then core
This is with the Zalman on a system-temp controlled fan header. Tomorrow I am going to try with the fan up all the way.
I tried some independant overclocking too. For my independant testing I use ATT to set the clocks and 3 loops of game 4 of 3d03.
The core is definately limited to 440 mhz - any higher gives me artifacts. The ram is up to 545 without artifacts and after an hour and a half of CSS, I saw only one artifact which might have been a glitch since it was in a non-high detail spot.
I would like to bring this card to 1.5vgpu with a volt mod however I do not know how much resistance I need to get there. If you see in the volt mod section, I want to add a smd or ceremic resistor to the card so there will be no variance in the voltage and no risk of it coming off. If anyone has any insite on how to get there, please let me know. I might just use the damn pots if I have to although I would much prefer a 'stable' method. 'Might do vddq and vdd too.
Now, mem timings. I've heard these aren't even safe to play with on video cards. Is there anything I can do there? I have cas latency, wr latency, cmd latency, and strobe latency. I also have trcdr, trcdw, trp, tras, trrd, tr2w, twr, tw2r, tw2rsame bank, tr2r. ALSO, there is mem refresh rate and trfc. No idea....
Anyway....
Default vgpu: 1.35
Default mem: 397mhz
Core / Mem
400 / 490 : stock
400 / 592 : max mem
