Build is in my signature.
So a couple weeks ago I got a new chassis for my rig (the old NZXT was too narrow to fit a new GPU). I managed it, but I wasn't sure if I'd scratched the motherboard or not. Thought maybe I'd dragged in on the standoffs a tiny bit. So I switch it on and everything works fine. About a week later, I get a BSOD and it gives me the "gathering information for report" or whatever it says, but it's stuck on 0% forever. So I force shutdown and try to restart it. Comes on for a second, instantly goes off, then starts itself up again, repeat endlessly. So I unplug it and narrow it down to the RAM. I've got four sticks, I removed the two secondary sticks and was able to turn it back on again. I don't know for sure what happened.
Worse than that, I had trouble with my drives being detected. If I fiddled with something and started it up again, sometimes it wouldn't detect my SSD (or either of my drives). I tried switching their SATA cables, switching out the power cables, etc; and eventually fiddling gets it working again. Had to go through an automatic disk repair once which worked fine. Then I go in to clean things up and fiddle a bit more a few days later and the same thing happens. Am I dealing with flimsy SATA cables? A dead power cable? Do I have to use a little more force than I recall when putting the SATA cables in? Could something be wrong with my motherboard?
I've pretty much been in a constant state of panic for the past two weeks (both my English and my grammar are impaired by this), so any idea would be greatly appreciated.
