overclockerchat
- Oct 15, 2014
The random reboots started almost two weeks ago. Prior to that I didn't install a new hardware or software.
The reboots is random. It happens while browsing, photoshop, games, idle, even while booting. Reboots can happen a few minutes of use to a few hours. Sometimes it reboots a few seconds while booting.
Temp is ok as I always monitor them and I dont overclock my PC.
I use my back-up gpu and then use the onboard graphic card.
I use my back-up 750w power supply. My system only needs 600w.
I use only 1 memory stick and tried all 4 memory slots.
I did a clean install of windows 8 wiping out all my previous data on my hdd.
I pull out the power sw and reset sw from the mobo and use my pc for a couple of minutes and then it reboots again.
Nothing of the above works.
Now my memory stick have been problematic for a long time as I need to reseat it a couple of times to work when I clean my PC.
Can a faulty memory stick cause my system to reboot randomly? I don't have a back-up memory stick to try btw.
Thanks in advance
Specs:
Windows 8
Intel core i7
ATI HD 4870x2
2tb HDD
Cooler master silent pro 1000w
g skill 4gb ddr3 1333
v6gt cooler
asrock extereme 7 gen3
Thanks in advance
Specs:
Windows 8
Intel core i7
ATI HD 4870x2
2tb HDD
v6gt cooler
