- Jan 24, 2002
Hello everyone. This problem is affecting the top pc in my sig.
Just a brief background on my setup. I've been running a dual boot winxp pro system for years. Never had a problem. I decided to reformat my D: HD and do a clean install since it was running a bit slower than expected. So i formatted the HD and once all files were copied and started to load my pc shuts down. I know my components work since I'm able to boot to the other winxp and am writing this question using the same pc. PCProbe says my cpu temp is 53 degrees so it's not a overheating problem.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
