Hey there, so I noticed that my PC has not really been performing as well as I believe it should be. I have a Ryzen 5 2600x, 16GB DDR4 3600Mhz (clocked to 3200Mhz) RAM, and a GTX 1080 8GB. Playing Modern Warfare, I noticed my framerate was around 100-130 FPS on normal settings with this build, though before on my i7 4770 build I had with the same GPU, i would get 160FPS on ultra settings at 1080p. I ran some benchmarks, and specifically, one I noticed that worried me was the unigine Superposition benchmark. My score was around 4005, with the average score being around 5000+. Im really not sure whats wrong, and its worrying me. Is my GPU just not functioning properly? Is windows just screwing my performance? Im not sure. I tried using DDU, disabling fast startup and fastboot (ive heard that helps performance sometimes), and im not sure what else to do. I would really appreciate it if someone could help.
Lastly, I dont know if it means anything but I noticed in CPU z in the graphics tab there is a thing called "perf level" and it says my 1080 is at perf level 0. I noticed in my BIOS there was a performance level for some things, but I left it on auto. I dont know if thats related or not but its worth mentioning.
Thank you
(If you wanna add me on discord and help me in greater detail, my discord is DSOThorn#0527).
Thank you
