- Jan 13, 2013
Hello to all members
Im facing some problems with my PC…
I have a Foxconn G31MXP (http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000416) with a Intel core 2 Duo E6450 and 2x2Gb DDR2 800 and a ssd 128gb kingston. When i first mount everything a couple of months ago all went ok and running normal till some days ago.
Primary the PC wont boot at 1st time…just till the 2nd or 3rd try that i was enable that the system booted. When it happened all was OK in Windows…all normal.
Now its almost impossible i can boot the system. Dispite the spinning of the cpu fan and the lights of power get on i cannot get the bip of the internal speaker and the PC wont boot.
I have already try another PSU (brand new one), another CPU (my old Celeron), another mems and eliminate all the possibility of some hardware error from HDD’s, Flopys, CD drives, USB cables, Sound Cables…ALL of that.
I tought that problem maybe a bricked bios so with some cost i acheived boot the system from a pen with a new bios and flashed it. The process went OK (i tryed too with the last 3 bios version from the Foxconn website) but the problem remains…
Do you guys know what can be the cause of it? Dead bios? Dead motherboard? (at first look all the capacitors look good without any aparent problem)
I have run out all the possibilities that i know…
Thanks in advance for all the help
