Hey guys,
Having abit of a problem with my dads computer, first, some specs;
This all came about after trying to flash the BIOS with a newer version, I got the error;
Then when I rebooted the system to try and find some BIOS protection option after the BIOS had loaded and the acer screen etc had gone instead of booting windows it just comes up with the message;
I have read about and people have suggested trying to fix the boot records, by using a bootable floppy.
I have done this however the computer won't boot to anything, I have tried removing the CD and HDD and booting from floppy however it won't, it just shows the same message, Verifying DMI Pool Data.
There is nothing wrong with the HDD as I have just put it in my computer and am currently writing this thread using his HDD in my system.
I have tried booting from CD (I have a windows 7 disk) and it just came up with the same message, it seems it won't boot anything and past BIOS it just shows this message.
Someone, please enlighten me with a magic fix for this,
Thanks
Josh
P.S I have also tried cleaing the CMOS by removing the jumper and battery and rebooting
Code:
[B]Acer Aspire T180[/B]
Acer EM61SM/EM61PM (Foxconn MCP61SM-AM Board)
AMD Sempron 3200+ CPU
2GB Memory
40GB Hitatch Sata HDD
Windows 7 Professional - 64bit
erase failure, maybe hardware protected
fwh rom is write protected
Verifying DMI Pool Data..
Thanks
Josh
