PCIe V.S. SATA m.2 adapter for 950 PRO SSD
smala
Hi,
I have Asus Sabertooth R1.0 mobo (https://www.asus.com/Motherboards/SABERTOOTH_990FX/specifications/) with FX-8350 CPU, and I'm going to get SSD (samsung 950 PRO).
However, I don't have m.2 in my motherboard so I'm going to get adapter for it. I see two options:
1) m.2 to SATA (for example http://www.ebay.com/itm/7MM-thickne...308252?hash=item21047e525c:g:0MoAAOSw5ZBWJ2Ct)
2) m.2 to PCIe (for example http://www.ebay.com/itm/2Port-NGFF-...410366?hash=item58c9f52d3e:g:VjsAAOSwDNdVuFIu)
I read other forums about 950 PRO with PCIe adapter, and if I correctly understood I need PCIe 3.0 x4 in my motherboard.
But I see I only have PCIe 2.0 x16 (x4 mode, black) (https://www.asus.com/Motherboards/SABERTOOTH_990FX/specifications/)
Is it enough for 950 PRO with PCIe adapter?
Or maybe I should go with m.2 to SATA adapter? I have 6 x SATA 6Gb/s ports, so 6Gb/s is enough for 950PRO. Also I don't find any threads about 950 PRO with SATA adapter (maybe PCIe is better?)
So in short: Should I get m.2 to PCIe adapter or m2. to SATA? Can I expect full speed of 950 PRO?
Thanks!
SATA = ~550MB/s max. No point to buy it for 950 Pro.
PCIe will be probably also limited on your board ( or by this adapter ). PCIe 2.0 x4 in theory can handle 950 Pro but I'm not sure if you make it work at declared by samsung speed on this adapter. For ~$8 it's still worth to try.
On the other hand I don't know if better option wouldn't be standard SATA SSD at double capacity in similar price. I don't think you will see performance difference in general use ... or you are working on databases or you move many large files really often.
Thank you! Just interesting why SATA III is declared 6Gb/s if it can handle ~550MB/s..
So I think I will try PCIe 2.0 x4 adapter. I think I will buy new PC in a few years so I'll better buy 950 Pro with PCI adapter than 850 PRO. I hope it will be faster than 850.
Thank you
Bit isn't the same as byte. Maximum bandwidth is 6Gb(its)/s what is about as much as ~750MB(ytes)/s but because of bus/controller limits it's usually not much more than 550MB/s per port and in docs you will see it's about 600MB/s max. Theoretical bandwidth is never the same as max real bandwidth.
This is the reason why all faster M.2 drives are directly connected to PCIe bus ( which has higher bandwidth ) or with drive you have PCIe adapter.
SATA uses 10 bits/byte to encode data (https://en.wikipedia.org/wiki/Serial_ATA) There is likely additional overhead. The theoretical maximum bandwidth is 600 MB/s (megabytes/second) That accommodates the encoding overhead but not the other overhead likely used to transport packets back and forth between PC and drive.
I too lust after SSDs faster than what SATA can support. :D I still recoil at the price premium. :(
