- May 27, 2002
- Ohio
Ok, so i had a few games i wanted to trade in at gamestop. Well, after i traded my stuff in i noticed they actually had this thing in stock! i had remembered hearing about this before. I was shocked to see it in a brick-and-mortar store!
Thats the thing i got.
It plugs into the USB, Ethernet, and A/V slot into the back of the 360. As you can see, it then gives you 4 USB ports, gets rid of the 360's proprietary A/V cable, and lets you use either Composite cables, Component cables, a S-Video cable, or a D-Sub cable.
it also has an Optical Audio out as well.
its NOT like the inter-cooler due to the fact that this does NOT plug into the 360's power port. This way, it won't over-heat and kill the 360 like the old style inter-cooler did.
as you can see, it doesn't go the entire length of the 360, thus it doesn't touch the 360's power port.
Thats the back of the unit. as i said, it plugs into the A/V port, the Ethernet port, and the USB port on the back of the 360.
now, i'm not quite sure how well this thing cools, BUT there is a great deal of heat being pumped out of the back of the 360 now that i put this thing on mine. Seems like its doing its job at helping cool the 360.
The thing i'm REALLY happy about, is the D-Sub port on this thing! I'm using a crappy 27" TV from walmart that cost like 75 bucks. the TV has Mono sound, not very good quality. Now, i have it plugged into the 20" Monitor, and have the 360 running at 1360x768. Sadly, my monitor only goes up to 1680x1050, so i can't run the 360 in the full 1920x1080. but this is MUCH MUCH better than the crappy TV.
I then bought some 20 dollar speakers, hooked them up, and bam. I'm now in love with my 360!
Also, i own a 1st gen Xbox360. So i'm always afraid that i will suddenly get the red rings of death. And i bought it off a friend, thus i don't have the 3 year warranty either. So i was looking for a decent 360 cooler anyways.
All in all, i'd say this was a DAMN good 30 bucks spent.
If anyone else finds this in a store, i suggest you pick it up. Pretty cheap at 30 bucks, helps cool the 360, and gives you many more options as to how you want to hook it up to your TV or Monitor.
Anyone else have this thing? Hear of any bad reviews on it? Any reason why i should take the thing off?
Oh, and i got it at my local GameStop.
