Greetings all,
I've completed the assembly of my rather unique and unorthodox cooling solution. Everything is hooked up and leak tested. But before I actually switch on the computer for temperature testing, I'd like to know if the numbers I'm seeing for flow rate and pump RPM are reasonable and expected, given my setup:
Equipment:
Setup:
*NOTE: sketch does not reflect actual tubing layout. I.e., the radiator cold return doesn't flair out the front of the rack
- GPM: 0.9
- Pump RPM: 3960 each
- Temps: Pending 24 hour run time average <- if anyone is interested I can followup once after I have data.
Equipment:
- Pumps: 2 VPP655 pumps in series
- Pump Tops: Heatkiller D5-TOP
- Waterblocks:
- --CPU is Heatkiller IV Pro Copper
- --HBA is Alphacool HF 14 Universal Block - Copper Edition
- --SB is Alphacool HF 14 Smart Motion Universal Copper Edition
- Radiator: Alphacool NexXxoS XT45 480mm
- Piping: All pipping and fittings are 3/8ID, 1/2OD
- Additional Flow Restriction Source: 4 sets of Swiftech Quick-Disconnetors
- Total Tubing Length: 9 feet
Setup:
