Greetings all,
I'm in the process of constructing my first cooling loop. At the moment, I have the loop setup outside the case for testing, sans radiator. Currently, the testing setup is like this: reservoir -> pump 1 -> pump 2 -> water block 1 -> water block 2 -> water block 3 -> reservoir.
The components are:
My question centers on the pumps speed as measured by the reported RPMs and the longevity of the pumps. To reach the magic number of 1 GPM though the loop, the pumps are currently running @ 4440 RPM each.
So my questions are:
The components are:
- Piping: All pipping and fittings are 3/8ID, 1/2OD
- Loop Turns: There no hard 90-degree turns
- Reservoir: Photon Res 270
- Pump 1 & 2: VPP655 Single Edition
- Pump Tops: Heatkiller D5-TOP
- WB 1: Heatkiller IV Pro
- WB 2: Heatkiller SB Rev3.0
- WB 3: Alphacool HF 14 Universal VGA Block - Copper Edition
- Radiator: Not present in testing loop
- Is this a normal RPM range?
- Will running at this RPM setting continuously shorten the life expectancy of the pumps?
