I intend to upgrade my build to 4gb ddr3, not now since i dont need it. I dont even have a proper video card yet. But the ram I have did give me some issues, but I got it working stable and fine since I bumped up the voltage to 1.75.
There are not many ram modules that are rated at 1.75 so that is an issue, but what other problems might I run into.
My first choice would be to sell the ram I bought and just buy a 4gb kit.
But a more economical solution for me would be to just add on another 2gb.
Do I need to have matching timings or is it just the voltage that needs to match? And what kind of realistic performance can I loose by using 2 unmatched ram modules.
or just screw it and upgrade with 4 more gb of ram.
