- Jan 24, 2011
- Zebulon, North Carolina
Let me get your thoughts on using Phase Change in general, and using it 24.7.
Iv'e heard these things are loud, now when i think loud, i think of a body shop, which is my line of work, loud in my home is about the dB of someone running 80 grit sand paper over a metal surface, if it isn't louder than this, then i can sleep through it (i have a baby and i'm used to noise).
The only issue i see is condensation around the CPU's base, or in the back of the motherboard, -45c freon hits a 30c surface it's inevitable, before i purchase this kit:
http://www.frozencpu.com/products/6...156_1366_939_940_AM2_Xeon.html?tl=g30c367s679
What are your thoughts on 24/7 use and it's pro's and Cons?
