- Dec 10, 2004
- The CircuitCity FireDog House
heya all, so i have my ac all bent up and in a rez , tommorow i am going to go get some denatured alcohol so its about time to start ordering waterblocks
so im going to get a 6002-lga775 for my processor block since its all copper
but i saw the cpu block they make that has a 226W pelt "thermoelectric" waterblock
http://www.sidewindercomputers.com/swmc7.html
since i can expect my chiller will probly do between -20 to -30C under load so the fluid will be around that temp when it goes into the pelt block.
so i was wondering what kinda temps will be the pelts lowest possible output?.
i also know that it would be just dumping heat into my cooling loop that would be on my videocard too however i looked up the compressor and it has plenty of capacity that will support a little over 500W. i cant quite recall but i think airconditioner btu rating is BTU@0C. i think i should be able to maintain below -10C coolant temps with a 400-500W load.
anyway you guys input would be appreciated.
by the way does anyone know of any pelt blocks for 7900 gt / 1900xtx models? i saw one that was for 9000-9700 models but i dont think those could handle a 7900 or 1900
