Man, you running that vcore at 1.6? You don't like that CPU do you? And 77c core temp is not good. We advise staying at a max of mid 50s c. under load.
What frequency are you running the CPU at now? Your images are so small I cannot make out the values in CPU-z. Please don't capture the whole desktop when you take screen shots. Use Snipping Tool in Windows Accessories to crop the relevant images before uploading them. You can upload three at a time and add more later with the edit button.
3.5mhz is a noticeable performance increase over 3.0 and 3.3 with Maya 2013 , Battlefield 4 and Total War: Rome ll so I've decided to keep that, I was able to lower the voltages to 1.368 ( May be able to go to 1.35 )
My Ram however is 3:8 , is there anyway to get that closer to 1:1
When the overclock started the freq was at 1033 and I turned it back up to 1333 before running prime95
also went from 6 clock to 9 clock cas latency but havnt noticed any performance drops
You probably need to lower your HT Link frequency. That one doesn't like to be overclocked much and stock is 2000 mhz. Keep it between 1800-2100 mhz.
And increase your CPU/NB voltage to about 1.225.
Please add the "SPD" tab to the pic cluster. That one is important as it shows us manufacturer recommendations for RAM timings and voltages at various frequency levels.
On my last motherboard I kept getting errors about the Northbridge frequency cant exceed something or whatever so I thought it best to leave it alone, errors included HT sync floods.
Should I adjust the frequency itself or change the setting from 10 (2000) to 9 ( 1900 ) and let it run at the adjusted frequency from the FSB increase
I tried to change the DRAM Freq clock timing from 9 to 8 in the bios and my computer didnt boot , could that have been the reason I needed 1.600v to stable 3.7mhz?
That first picture is kind of blurry.
FSB - 234
CPU multi - 15
CPU_NB ratio -10
DRAM freq - 1066
Man, your bios uses the strangest terminology I've ever seen! "Advanced DRAM Configuration"? Well then, put it back to 9x. Apparently, it's not liking a large disparity between the CPU/NB frequency and the HT Link Frequency, which will be limiting.
Well at 8x my ht link speed is at an acceptable speed
the gains between ram speed + higher timings vs low speed and shorter timings only really effect synthetic benchmarks so I suppose I could leave it be
I wonder if the AMD branded Radeon RAM is good for overclocking? Its suppose to work well for people using it in conjunction with radeon r200x and XDMA
Edit: Im just trying to justify buying new things dont listen to me lol
Are you saying the Northbridge itself is hitting 60c? That's certainly not excessively hot for a northbridge temp but if you mean the socket temp is hitting 60c then that's about the max you can expect before encountering instability. It can be difficult to sort out exactly what component is being reported on in the HWMonitor TMPINx section. A lot of motherboards anymore don't even have a NB temp sensor per se but there are sensors nearby.
The max I would try to run on that CPU is 1600, at 1333 you can tighten it a bit if possible but personally I wouldn't bother with new ram for the benefits you'll see. I'd save my pennies and do a full upgrade soon. But that's just me.
