- May 15, 2010
- Euroland, Denmark
Hey guys
I am trying to decide one which motherboard i should get for my Pentium G3258.
Since this is a budget build, the budget being, it has to be cheap as possible.
So i have boiled my choices down to these three boards. I am going to list the Pros and cons that i like, and they are not specification related.
NOTE: mATX!!
What i need to know now, is why i should pick one board over the order for hardware reasons.
1. Gigabyte GA-Z97M-D3H (rev. 1.0)
http://www.gigabyte.com/products/product-page.aspx?pid=4970&dl=#ov
Pros -
I like the orange, it will give my an option for colors in the build.
I can get 4 years warranty
Cons -
There are only 2x SATA ports that have a 90degree bend - I would prefer all 6 having this.
Motherboard pcb is brown
2. ASRock Z97M Pro4
http://www.asrock.com/mb/Intel/Z97M Pro4/
Pros -
Black motherboard PCB
90degree angled Sata port on all 6 ports
I have liked ASRock bios's in the past
Con -
I have had an unhappy RMA experiance with ASRock, but it did work out in the end.
Not a big fan of the blue.
No extra long warranty.
3. MSI Z97M-G43
http://www.msi.com/product/mb/Z97MG43.html#hero-overview
Pros -
Sata ports are angled 90degrees
USB 3.0 is angled 90degrees.
M.2 socket
Cheapest
Cons -
PCB color, looks more brown than black
Still not a fan of blue
No extra warranty
Not a big fan of the MSI bios's i have used before.
As far as hardware, all the boards boast of uprated caps, and so on, so i really need help on making the right choice.
This is purely from a hardware point of view, which will perform the best.
They are priced within the same area +/- 10$
NOTE: mATX!!
Pros -
Cons -
2. ASRock Z97M Pro4
Pros -
Con -
3. MSI Z97M-G43
Pros -
M.2 socket
Cheapest
Cons -
No extra warranty
