- Nov 26, 2005
- Concord, NC
I have a Thermaltake Armor case w/ the 25cm side-door fan. I put 2 of these fans up front for intake:
Delta WFB1212HH 7-Blades
120x120x25mm
2800 RPM - 95.35 CFM
42.5 dBA - .68A (8.16W)
I upgraded the stock 600rpm 25cm side-door fan to an 800rpm model I found online and mounted it externally to make room for my Thermalright Ultra 120 Extreme CPU cooler.
I cut out all the fan grills on the top and back of my case, and put 2 of these 92mm fans on the top and rear for exhaust mounted externally and internally, respectively:
Panaflo H1A 92mm Fan (BX) w/ RPM Sensor
92x92x25mm
2850 RPM - 56.8 CFM
35dBA - .225A (2.7W)
I also stuck 1 of these on the back for exhaust also mounted externally:
Panaflo FBA12G12U:
120x120x38mm
2705 RPM - 114.7 CFM
45.5 dBA - .51A (6.12W)
On the CPU cooler I used 1 of these:
NMB/MINEBEA 4715KL-04W-B59:
120x120x38mm
3600 RPM - 130 CFM
50 dBA - 1.3A (15.6W)
I also have an Arctic Cooling Accelero Extreme GTX280 on my GTX280 graphics card which has (3) 92mm fans, and a PCI-slot dual-fan cooler mounted above the card to keep the back-side of the graphics card cool. I have a small spot-fan pointed at the RAM, and I'm using one of the squirrel-cage fans that came with my motherboard on the MOSFETs around the CPU socket.
The case is very quiet with all the fans turned down, and still moves a massive amount of air. It's loud when you crank it, but nothing like my old 92mm Vantec Tornado.
I'll post up some temps when I get some more time.
120x120x25mm
92x92x25mm
2850 RPM - 56.8 CFM
Panaflo FBA12G12U:
120x120x38mm
120x120x38mm
3600 RPM - 130 CFM
