- May 4, 2001
- Los Angeles
- Thread Starter
- #121
Try to increase CPU FSB little at a time and test for stability. As long as you keep it under 65c load, you should be OK.
njkid32 said:Hey everyone I have posted this at XS but I will try and keep this up as well. Here is the latest oc on air still. I am waiting on the Mach1 to come in the mail and the mod kit. Anyway here is a SS....
Robert where are you at on your oc..
I also did a couple of little changes to my rig. I put a HS over my PWMIC so it runs a little cooler and then I put a 90mm fan at the bottom of my case cuz I found an area under my vid card and in front of the chipset...
nOx34 said:Wow your temps are awesome ! I bet I could hit 2.9 with temps like that !
Look at mine
Embarassingly hot in here
njkid32 said:Hey nOx34 did you pop the top off that thing? Cuz I did and it made a hug diff! My ss is at idle with my TT Big Typhoon. Is yours under load or is that at idle?
hitechjb1 said:May I ask what week is your X2?
Robert said:I'm going to try this cpu with DFI LANPARTY UT nF4 Ultra-D board. What is the recommendation on BIOS and setting?
Scroatdog said:Cool. Thanks for the info.
Who was it that will sift through weeks to find the week you're looking for? Is it Monarch?
njkid32 said:Hey Robert how ya doing? I would go with the 704-2BT bios it has worked really well for me. Here is a link its the last one on the list----
http://www.bleedinedge.com/forum/showpost.php?p=85953&postcount=1
