Hi First I like to say to hello to every one as you know am new to the site........
but have been reading allot on it .......
I am running these items below...
Asus Rampage Extreme Intel X48 (Socket 775) PCI-Express DDR3 Motherboard
Corsair 4GB DDR3 DHX 1333C9DHX Twin3X (2x2GB) (TW3X4G1333C9DHX)
Tested together at 1333MHz, Vdimm = 1.70V, at latency settings of 9-9-9-24
- SPD programmed at:JEDEC standard 9-9-9-24 values at 1333MHz
Intel Core 2 Duo E8500 LGA775 E0 steppping ……
Zalman CNPS9700-NT nVidia Tritium CPU Cooler
I have been trying to get this to over clock with the guides here ...
I got it to got to 4200 mzh with 70c load temp on prime95 ..
was 12hours prime stable...then i stopped it.......
has been working fine but then i started to get BSOD after using it for a fews hours ........
Done a memtest86 after 2 passes it would thro halt errors...
set it back to default ...re-tested the ram ...at
9-9-9-24 values at 1333MHz 1.7 volts ......runs fine 30 plus passes...no problems .......
Cpu when OC was running at 4180 Mhz 440FSB x9.5 Mutiply
any help or advice or bios settings would be great ...I have tried but just not there....
Oh had to up the v core a notch or two cant remember how much thou ..was not much thou
Just goes to show being prime95 stable does not make the pc stable.....
thanks for any help in advance ....
