blueurmind85
- Dec 9, 2015
Hey everyone,
This is my first post here as well as being new to overclocking, so please bear with me.
I'm running:
MOBO: GA-890GPA-UD3H (rev 3.1)
CPU: AMD Phenom II x6 1055t
RAM: CML32GX3M4A1600C10B (CORSAIR Vengeance LP 32GB (4 x 8GB) DDR3 1600)
I recently upgraded to this RAM and am having a lot of difficulty underclocking it in order to overclock my CPU. I finally got the RAM stable with CPU at stock settings by dropping the multiplier down to run the RAM at 1066MHz with the timings set to "Auto" (SPD - 7/7/7/20/26 @ 1.5v). I just learned about single/dual/quad rank RAM from Corsair's website and they had a helpful little graph showing that my CPU cannot handle this configuration of RAM above 1066MHZ.
Here's the problem:
Before I upgraded, I was running 8GB (2 x 4GB) @ 1333MHz (9/9/9/24) and could get the CPU to overclock stabily to 3.5GHz (no voltage increase) by running the core clock at 250 and setting the RAM multiplier at x5.33 which put the RAM at 1332MHz. Now that I am dealing with this RAM that won't seem to cooperate at that speed, It seemed logical to drop the multiplier down to x4 which put the ram at 1000MHz. Every time I save the settings after trying (many, many) different timings, after restarting I just get a message saying that the system has experienced boot failure due to overclocking and that it has been reset. After a while I tried putting the CPU back to stock and running the RAM at 800MHz with timings set to "Auto" (which matched the corresponding SPD in CPU-Z) and the same thing happened.
Does anyone have any helpful insight? Am I just screwed because I can't run this RAM at any other speed than 1066MHz? Is there a feasible way that I might be able to under/overclock this RAM lower/higher than 1066MHz to accommodate overclocking the CPU? I've tried tweaking the voltages and that doesn't seem to help...and I don't feel I should have to to underclock the RAM especially because the SPD for 800MHz states the lower timings should work at 1.5v.
For what it's worth, my motherboard's revision does claim compatibility with AM3+ CPU's with the latest BIOS and I do intend to upgrade to a black edition FX processor at some point which looks like it will provide a much easier time with overclocking. If that's my only solution, than so be it!
Any input is greatly appreciated. Thanks!
I'm running:
Here's the problem:
