- Mar 15, 2014
Hello. I was wondering if it would be bad to install a radiator in every possible location of a case?
My build is
I7 4770k (delidded)(heat killer rev3.0 copper block...I mite naked mount it)
Asus z87 pro mobo
16gb 2133 corsair
Sli super clocked evga gtx 780 ti's (ek full blocks ran in parallel)
Rm1000 PSU
120gb evo ssd (os + APS)
500gb evo ssd (games)
3tb HDD (movies)
1.5tb HDD (3d movies)
1tb external (backup)
All of the water blocks and other cooling supplies will be here Wednesday and they include.
The 3 blocks listed above
240 (30mm) rad
280 (60mm) rad
Mcp655 pump
250mm res
Koolance pump top
Evga ti backplates
Plus all of the odds n ends
Now I'm removing the 5.25 disk drive bay so the define r4 will be completely bayless and that frees up enough space for a 3rd rad spot in the top. So I could do a 360 insteadvof the 240 with a little bit of hole drilling.
I also still have a spot for a single 120 and a single 140
Should I stuff as many rads as possible in it or stick with the 280+240 loop?
Here are the updated pics.
My build is
Asus z87 pro mobo
16gb 2133 corsair
Rm1000 PSU
3tb HDD (movies)
240 (30mm) rad
280 (60mm) rad
Mcp655 pump
250mm res
Koolance pump top
Evga ti backplates
