- Oct 3, 2011
without calling them dumb
so i posted about my laptop turbo stuck at 2.3ghz
http://www.overclockers.com/forums/showthread.php?t=724737
i ended up need to contact HP....
i sent them this
1st NOT a intel laptop... did he bother to even look at what laptop im talking about?
i just replyed
i sent them this
they sent backthe turbo on my laptop is defected
it stays at 2.3ghz it will not down clock to 1.9(stock) or lower and will not go to 2.8ghz (max turbo)
the CPU is always stuck at 2.3 no matter what
Bios was flashed to try to fix this. it did not.
something is defected on this laptop I don't think it is software but not sure
the software im reading the speeds is called CPUz its a high grade software made for this purpose.
Thank you for contacting HP Total Care.
On reviewing your email I understand that you have some queries about Turbo Boost Technology in your HP Pavilion g7-2243us Notebook PC.
I greatly appreciate that you have forwarded the matter to us and I as an HP- Tech support take the ownership of the email and I assure you to answer the query to the best of my abilities.
******, in response to your email I would like to inform you that Intel turbo boost Technology is a method for dynamically over clocking processor speed for use and improve the systems performance. If your computer is configured to use Intel Turbo boost, processor speed will increase based on system requirements and application demands (up to the configured maximum amount). When it is no longer needed by an application, the dynamically allocated portion of memory is returned to the operating system for other uses. When workload on the processor calls for faster performance, and the processor is below its limits, the processor's clock will increase the operating frequency in regular increments as required to meet demand. If Windows is not asking for more performance, Turbo Boost does not deliver it. The Turbo Boost is activated and deactivated automatically in hardware as per processor requirement. Hence, manually it is not possible to CPU to run faster; it will increase the speed as per the processor requirement.
I would suggest you please download Intel Turbo Boost Technology Monitor from the link given below. The Intel Turbo Boost Technology Monitor 2.5 is a Microsoft Windows application that displays processor frequency changes including Intel Turbo Boost Technology frequencies.
http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=19105
i just replyed
hello
first thing this is a AMD APU 4500m not Intel
also the CPU is locked at 2.3ghz no matter what setting set. it does not reach its max turbo speed even when needed and its not getting over heated
it May be a issue with the turbo not 100% sure i think its a sounds like something is wrong with the Motherboard and/or CPU
i contacted you guys to see if there is a fix for this issue or repair is issue
i also know how turbo works only giving the extra when needed however it is Not working properly as i said turbo goes to 2.3 Max when its should go to 2.8 (even a spike would count)
