- Oct 18, 2002
- Los Angeles
I tried looking for pictures of the h240x to see if it would be possible to cut the mount on the pump/reservoir in order to fit a 2nd 140mm fan in it's place so that you have 4 fans, 2 pullsing and 2 pushing for a push/pull configuration. I can't find pictures that show how the hoses are mounted to the radiator...
If one of you guys have the h240x could you let me know if it would be possible to cut away the mount on the pump/reservoir, or maybe bend it "back" and reposition it so that a 2nd 140mm fan can be mounted where the pump/reservoir sit?
