Hello OC,
Putting together a new system with the components below:
Case: CoolerMaster ATCs-620B (Possible upgrade to SilverStone CW02)
Mobo: Asus Maximus V GENE
CPU: i7-3770K
Cooler: Thermalright AXP-140
RAM: 16GB (4 x 4GB) Ripjaws X 2133MHz
SSD: Intel 330 Series 120GB
PSU: Kingwin LPZ-550 Platinum
VGA: ????
I'm looking for a mid-high performer that doesn't use a lot of power or put out much heat/noise. This will be a multi-purpose box; HTPC, Media/Torrent Server, VM Server, and light gaming. I play WoW only a few hours (~20) per month and don't raid much, maybe once per month. I like the ATI ZeroCore feature as when not being actively used, I will switch off the TV and hopefully reduce the power usage.
So far I think my choices in order are:
1. MSI R7950 Twin Frozr III
2. PowerColor 7950 PCS+
3. Gainward GTX 680 Phantom
MSI is first due to the brand's rep and larger product range. PowerColor is harder to find, 2 OC'ers have had to RMA in past few weeks, and limited supply=long wait. The GTX is a buttload of $$$ ($800) compared to about $430 and $530. Is that price difference worth it in your opinion? What order would you put those cards in? Open to suggestions.
Cheers
CPU: i7-3770K
VGA: ????
Cheers
