So, you all probably get this a lot.
I'm new. Planning on building my first *true* desktop, and I'm looking for some input. You see, I have a decent amount of knowledge. I know how to tell if the parts I select are compatible and stuff, but the one thing I don't know is if I'm getting the most power for the best price. Hence my coming to these forums.
So, here are the goals:
1) Building on a budget (didn't see that coming!) of 600 - 800. I'd honestly prefer to keep it close to 650/700, but you might convince me otherwise. By the way, the total price will also include the OS. I know, that puts me in a handicap, but I need to budget.
2) This will gaming computer. My plan is to be able to play (don't judge me) Lord of the Rings Online, Skyrim, and Guild Wars 2 on at least the medium settings, if not high.
3) To understand more about computer parts.
4) The build to last a few years. Looking to include a quad-core and everything necessary to make it last.
So, I hopped on newegg and started looking at parts and put together this list. Now, I just said I know which parts would work together, so hopefully I don't go embarrassing myself by posting parts that won't work.
I copy/pasted the titles newegg had for the parts incase you didn't want to follow the links.
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
COOLER MASTER eXtreme Power Plus RS-550-PCAR-E3 550W ATX12V V2.3 SLI Ready CrossFire Ready Power Supply
ASUS M5A97 LE R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOXr
ASUS HD7750-1GD5-V2 Radeon HD 7750 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
Kingston HyperX Blu 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3B1K2/8GX
Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive - OEM
LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEMe
Microsoft Windows 8 64-bit (Full Version) - OEMS
So, some notes on my decisions.
I considered getting a SSD, but load times just don't really bug me (yet).
I wanted a quad-core. Figured it would last some time.
Since Windows 8 was the same price as 7, I figured "why not?"
If I recall correctly, the video card I picked can do that cross-fire thing (which, to my understanding, is having dual video cards).
Everything else seemed like a good decision. According to newegg, everything is about $680.
So, here comes my request. Would this computer work together well? Are there different parts that I should consider? This would be my first true build. Everything else I've built has been either half put together already or from a pile of scrap parts.
Thanks in advance!
Thanks in advance!
