Hi, new here.
So I've been having issues with bsod error 50 pagefaults. 99% sure it's hardware at this point so i swapped ram, stress tested the video card and just tonight ran prime95. I've got an old rig, Athlon 64 x2 6400. Cpu 1 on the small FFT always errors on the first test, Cpu 2 seems to run fine so far. Both fail on an in-place large FFT, cpu 1 on first pass, cpu 2 around 3rd-5th pass.
Anyhow, using cpuid I noticed my cpu vcore drops from 1.48~ to 1.088~ for like a second when prime95 starts. The textfile said this may indicate a PSU problem and I should check these forums. My PSU has about 6 (edit, actually closer to 9) years on it, antec 600w active pfc something or other iirc.
Thoughts? I guess I should mention the pagefile bsods or program crashes are more frequent when the room temperature is hotter, but I'm not in any danger zones by cpuid (neither board nor cpu ever over 80c at peak), but my psu exhaust is notably warmer than anything else by touch.
