- Aug 27, 2003
- Mississauga, Ontario
Hello, just wondering, is Prime95 still relevant as a test other than just to see temperatures at max usage? I mean specifically the 8150 overclocked (or any 8 core chip), does it actually test everything? I am still using the old P95 that you have to load a bunch of, but on my second computer that I just built with the 8150, I redownloaded P95 and now it appears you only need one instance and it shows all the cores and how they work.
However, in the store where I bought the H80 cooler, I was talking to the guy and he says Prime95 doesn't test the CPU functions now at all, or only a few of them, and mentioned some other torture test but I forget the name. If P95 is not adequate, what is the alternative? And furthermore, P95 still fails after an hour on a serious overclock so that means that it must use some function of the CPU, or FPU that is still used primarily on new cpus.
And for memory, is SuperPI32 still a good indication if the memory is stable at a certain timings/freq settings if it succeeds in 32M digits, and if not, what is it's alternative?
What programs should I get to torture test my cpu after an overclock, and my memory, for both stability and max temperature? I would like to stick to P95 but I can switch, there is no loyalty or anything, I'm just used to it.
Thank you in advance?
