- Feb 6, 2003
- up state NJ
i've been looking at watercooling again for a new build.
i noticed on youtube quite a few users complaining about Primochill VUE coolant being abrasive & clogging.
it's removing nickle plating , removing material from blocks, block covers, and reservoirs, clogging micro channels in blocks.
anyone using itmay want to should take a look at your blocks, fittings, rads, etc and seriously consider switching.
while the pearlescent fluid looks really neat, its apparent abrasive & clogging properties FAR outweigh that.
i can't speak from experience, but i would NOT run anything like this. i'm going with distilled water & silver kill coils.
if you use Primochill VUE i would appreciate your input.
/max
anyone using it
/max
