Okay. I recently bought an AMD Athalon XP 3200+ Barton for my computer because my old one was crap to say the least. When I put it in I checked the speed and it was running at a little less then 1.1 ghz. I tried going into my BIOs and realized I had no idea what I was doing.
Here is some info on my hardware as it was on newegg.com because Im lazy x_x
RAM: KINGSTON KVR333X64C25/512 512MB 32x64 PC2700 DDR RAM (better than 2100 2400)
6 Layers High Quality Board; CL 2.5; 184-Pin Unbuffered. Requires DDR supported Motherboard
Mobo: Gigabyte GA-7N400-L, nForce2 Ultra400 chipset for Socket A ATX motherboard RETAIL
Specifications:
Supported CPU:AMD AthlonXP / Athlon / Duron processor
Chipset:nForce 2 Ultra400 + MCP
FSB:400/333/266/200
RAM: DDR*4 (dual channel) DDR400/333/266 Max 3GB
IDE: Dual channel Ultra ATA 133/100/66 Max 4 Devices
Slots:1 x AGP pro slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only. 5 x PCI slots (PCI 2.2 compliant
Ports:2xPS2, 2xCOM,1xLPT,1xLAN, 4xUSB and Audio Ports
Onboard Audio:AC97 (ALC650) 6 Channel onboard Codec
Onboard LAN: Realtek 8100C 10/100 Ethernet
CPU: AMD Athlon XP 3200+ "Barton", 400MHz FSB, 512K Cache Processor - OEM
Model# AXDA3200DKV4E
Item # N82E16819103391
Specifications:
Model: AMD Athlon XP 3200+
Core: Barton
Operating Frequency: 2.2GHz
FSB: 400MHz
Cache: L1/64K+64K; L2/512K
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: OEM(Processor Only)
Yeah... I went to advanced chipset features in my BIOs and it only had like 4 things.. FSB Frequency, Memory Frequency, AGP Frequency, and Resulting Frequency.. I think thats it. Please help! I just want to get it up to 2.2 ghz!
If you need any more info just ask Ill be more then happy to comply.
Specifications:
FSB:400/333/266/200
Specifications:
Core: Barton
FSB: 400MHz
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
