I just finished putting together my first water cool system but the flow is too weak. I see the water flowing through but it barely moving. Here is my set up, I am using thermaltake the tower 900 case:
Reservoir (laying horizontally)>Pump1 (position lower than reservoir, right side of the case)>Pump 2 (position lower than reservoir, left side of the case)>Radiator 1 ( higher than reservoir and pump, position vertically, on left and back side of the case)>Radiator 2 (position vertically, right back side of the case)>GPU 1 > GPU 2> Ram 1 > Ram 2> CPU Monoblock (all components are positioned at the highest point, the case design) > reservoir
Due to the case design, I ran quite a number of vertical tubes (6) and 2 radiators that requires the pump to push the water up vertically. I am not sure if this cause the problem that my flow can't seem to flow through the system.
