- Mar 18, 2015
Ive created a working Universal Install disc using the instructions found here, but there is one small hitch and I hope folks around here can figure it out and lend a hand with it.
As I said Ive successfully created the universal ISO. It can be written to USB with rufus/any other USB creation tool or burned to a DVD. No problem there. The problem comes in when I try to use a restore disc. I am prompted to use a disc that fits the version I am running. The first time this happened I simply went and remade a restore disc from within the OS and tried that one.... still a no go. Its not a huge problem because diligent imaging is an effective workaround, but I would still like to figure this one out. As it is, my guess is that the restore disc tries to read the ei.cfg (or whatever it turns into after install) and cannot find it. My eventual plan is to combine my universal disc with the updates found in this thread, but as I said I would like to have all the kinks worked out first. Thanks in advance
