- May 9, 2004
- Check your Six...
Ok, I got my wc external unit setup, well I filled the res up with water, and pluged the pump in (ehiem 1250), it started to suck all the water from the res, so I started to fill it back up, well now its not sucking an pushing the water all the way thru the system, and it has a lot of air bubbles, and the biggest one is from the res to the pump. Here is how I have my setup
Here is a list of hardware Im using
Pump - Ehiem 1250
Heatercore 77' Bonivlle
Block - DD TDX socket 478
Res - DD Single Bay Res 5 1/2
All fittings are 1/2
on the Ehiem 1250
bottom line of the pump> res > heatercore > block > res > top of the pump.
I have mad air bubbles, and cant seem to find out why the pump isnt sucking and pushing all the water...
Any help would be appricated. I can take pics of the setup if needs be.
Pump - Ehiem 1250
on the Ehiem 1250
