- Dec 17, 2018
Hello,
We are having issues with a
Asus rampage 2 extreme
Xeon x5675
and msi rtx2070 aero.
Im trying to finish my girlfriends computer. Due to a faulty 1070ti we got a new 2070 as replacement. Warranty deal.
The issue now is that the computer wont give any screen with the 2070 installed.
The card works just fine in my computer but not in hers.
I tested the system with other cards and they all work fine.
gtx 1050ti
gt 710
Radeon Hd4850 (only card with 6pin power needed, used to check if my psu was giving power. And it works on both psi power cables (2070 needs 1 8pin and 1 6pin))
Update:
tried a different psu. Almost brandnew 750w corsair r750mx and it didnt work.
Are there settings in the bios that i need to check or will it just not work.
Greetings Sven
Xeon x5675
gtx 1050ti
gt 710
Update:
Greetings Sven
