You can't create a FAT32 partition in less than 2Gb. You can create and install 98 on FAT partitons.Skeletor said:In addition, on another computer (p150, 16mb ram, 1gb hdd) I can't use a win98 fdisk to create a FAT32 parition. It keeps trying to verify the drive. What's that about?
Skeletor said:I've tried to install win 98 on my computer (celeron 600, 64mb, 20gb hdd) but after the whole process it hangs at the win98 restarting window. When I reboot, it says "unreliable xms memory at address 03004414.
What to do?
Audioaficionado said:You can't create a FAT32 partition in less than 2Gb. You can create and install 98 on FAT partitons.
However TTBOMK it will refuse to install with less than 24Mb of RAM because the GIUs will take too much of the low level memory to install. There is a way to install it without hardware checks and GUIs using some command line switches but 98 will run like crap on that box until you put at least 32Mb of RAM on it. 64Mb would be much better. I installed 98lite on a 16Mb 486 but soon deleted it and installed a 16bit DOS6.22/win3.11 & NT4. Even 98lite was too slow on that ancient hardware eventhough I'd upped the RAM to 64Mb.
These guys have the skinny on running 98 well on old machines including those command line switches. In fact I only run 98lite on any box where I need 98.
http://www.litepc.com/
http://www.litepc.com/faq3.html#2
JimmyG said:For the first problem, you may have some bad ram. Also, 64megs is not enough to run Win98 very well. You should add some ram....it's cheap.
For the second problem, an old computer like that probably doesn't support fat32 in the bios.
Please tell us how and there's no reason to be rude.RJARRRPCGP said:Wrong!!! You can create a FAT32 partition less than 2 GB.
