I hope I'm not jinxing this by making an update, but here goes.
So, ever since my post on the 12th of February, I haven't had a single POSTing incident. Unfortunately I'm not sure which of my little fixes seems to have solved it, but here's a list of what I did:
Updated my bios to the latest one Asus has, 1405.
Turned on VDDCR CPU Power Phase Control to extreme in the bios.
My EVGA 1000w PSU had a switch in the back for an eco boost mode. It was turned on so I turned it off. According to their website, all it does is not run the fans until the PSU reaches 55 degrees, but... where's the eco in that? So your fans run a little less and that saves the planet? I figure it's got something to do with the way it feeds power into the computer as well, and might be where the issue is during a system boot.
I also read from my motherboard manual, accidentally, about the way you should turn on a built system for the first time. Peripherals should be turned on first, and then the main unit. So nowadays I turn my monitor and speakers on first.
Finally, I rearranged all my USB peripherals and only put them in 2.0 ports since all I'm using are keyboards, mice, controllers and microphones. No exterior disks or such that would really benefit from 3.0. Never had any issues with this before the new memory sticks, but whatever...
My main suspects are the BIOS, the Power Phase Control and the PSU button, really.
