- Dec 19, 2000
Thanks to pik4chu I recieved two Optoma ST320 thin client boards that origionally ran Windows CE 4.0. These are really just tiny x86 PC boards so running a different OS is not a problem. With parts from two machines I was able to get 1 up and running. The specs dont sound like much but then agian these machines were only designed for win CE. The CPU is a National Semiconductor Geode GX1 running at 300mhz. Ram is a 144pin 64MB from a notebook. For hard disks I recieved an 8mb disk on chip which looks like an old bios chip. The other drive is a 32MB Apacer IDE flash drive. I dug around ebay and found a compact flash adapter for the 2.5" IDE on the board. This means I can run a 2GB CF card instead of the 8MB or 32MB solid state drives. The only problem I can see with the CF adapter is a few capacitors are in the way. This is nothing a little soldering cant take care of.
My plans for this rig are, no moving parts, and a custom lexan case. So far I have a few pieces of lexan cut to size so I will start putting it all together soon.
Ubuntu Linux is barely smaller than the complete system
Here is a better pic of the board. Each X represents components I may relocate. I didnt want the PS2 ports on the front and the power button is getting changed completely. The capacitors are in the way of my new CF to IDE adapter. USB ports I think I still want on the front but in a better location.
I got this switch from an OCF member ages and ages ago. I will finally get to use it here.
Not bad for $20 shipped
I will continue to update and streamline this thread as the project progresses. I will try to get pictures from each step of the lexan case construction. Now the question is what do I do with this rig when its finished
