- Aug 18, 2002
- Mean Streets Of Orange County CA
Looking Good Vonkaar
UberBlue said:Please tell me you're not going the ghetto route in regards to bonding the acrylic. IPS Weld-On 3 or 4 is the stuff to use.
As far a scratches...
Novus 2 and 3 are your friends. I love the stuff.
Posidon42 said:
I am getting ready to do some plexi work myself. Where can I get these products? I don't have anything for the scratches right now but I was planning on using plastic weld for joining my panels.
vonkaar said:haw... Xoxide used to have it but they are always out of stock now days.
I have novus 2... never seen the 3 in person. They sell the stuff at my chrome shop ^_^.
Otherwise...
http://froogle.google.com/froogle?q=novus
Thanks for the suggestion UberBlue. I have a good acrylic bonder but I'm going to try out the IPS stuff. I read a couple reviews on it and it seems like it may be better than what I have.
Good place for it:
http://www.tapplastics.com/shop/product.php?pid=131
Hell... while we are at TAP, they stock Novus 1, 2 & 3 =p.
skahtul said:THIS is the stuff I used to "glue" a plexi-glass reservoir together with. Like it says in the description, it is Ultra Clear, you can't even see the glue between the seems. And it is VERY strong.
Also, just a question vonkaar, are you going to mount your heater cores stacked like in the picture?
GREAT job on that bending of the plexi. I hope I get it down that good when I have to do it in a few weeks.
vonkaar said:skahtul: Yes, I am going to mount the pair of heatercores in a series like that. The blower pushes through them like they weren't even there ^_^.
