- Sep 7, 2013
Shouldn't be any vibration with the rubber in there eh?
Can't wait to see the sleeving pics!!
Sucks that it cracked Benny but that takes a lot of time and skill to cut all those holes so props to that
The fan shrouds you drilled look great!
It's really coming along Benny!
That really sucks about the cracks, I've had similar problems as well with some work that I'm doing. Thankfully, my work provided some of the 1/8" copolyester that they manufacture. I just cut with it this morning and couldn't believe how crack resistant it was. I was testing its limits and could hold the cut piece in the air with my hand and drill a hole close to the edge without any cracking *gasp* I hope my work signs off on me announcing the product because I think it'd be a new modders dream.... even though it's extruded
But as of your vent designs, I really like how the left one has the 'X' in it with the bigger spacing and holes. The middle design is awesome bordered with the two circles. Great job on the drilling, it seems you learned a lot from the first to last drilling.
Thank you =) yeah this took quite some time. for the mini holes i needed half an hour alone, then i decided to go another way ;D
Thank you.
Copolyester is used for drinking bottles?
i havent seen any in your log, only aluminum ;D
and yeah i had enough time to learn ;D
Sweet! Awaiting pics!
Good luck sleeving, while a pain in the butt most times... I've found it quite therapeutic.
That sleeving is really well done and clean for a first timer. Great job!
Yeah wow! Those cables look great!!
I've always wanted to do that too... I might have to know those are sweet looking!
Looks really clean Benny! Nice job!
Those look sleek benny!
I personally love the way brushed metal looks vs any other finish.
