- Mar 18, 2015
Here's my issue guys,.... I picked up a couple of 20 in monitors to replace the ones that arrived poorly a few weeks back. They are Acer P205h's to be exact. I had to give up some screen property, but now I have working monitors But..... I'm getting bottleneck ed by a projector I have added into the system. Here is the set up: a PowerColor HD 7850 with one dvi port headed to one monitor and the other running to a dvi splitter with the other monitor and the projector (NEC VT 595 recommended resolution 1024 x 768) . In the past I have used the CCC to add the resolutions I needed (with a few sets of generic monitors on through the recently deceased Dell e2310hc) and all has been excellent. I would have to adjust the resolution down to a viewable level when using the projector (which is usually off - hence not a problem to have the monitor it shares a connection with at a higher resolution). But now I'm getting a problem where I don't have any resolutions to choose from the the projector connected monitor. Also I cannot add in the resolution I am trying g to get (1600 x 900).
I have tried a tutorial that suggests editing the registry to add custom resolution
Also I made sure to be using dual link dvi cables (made that mistake a different time)
Is there a better way to set this up? I don't recall if the projector has hdmi support, but I suppose I could have the projector separate.... I'm just stumped.
