- Jul 2, 2001
- wolverhampton, england
Hi guys,
First off i need to give you the system info, having finally decided on the components i will be using so here they are...
Core 2Duo E8400 - (Will overclock to 3.3ghz or there about initially)
Asus maximus 2 formula
4Gb OCZ Reaper 1066mhz DDR2
Powercolor HD4890 PCS Battleforge Edition 1024mb DDR5
250Gb western digital sata drive
Liteon dvd/rw
Could you guys suggest a VERY cheap PSU. Im looking for the cheapest possible psu i can get, obviously i dont want a £10 piece of junk that will end up killing my system I would however like to keep it below £35 if at all possible.
I will in the near future be upgrading to Xfire and then will spend alot on a 800W+ quality psu but for now i need a dirt cheap psu to get my system up and running. I mention overclocking the cpu a little initially but i dont mind running it stock for a few months until i upgrade the psu.
Any suggestions gratefully recieved
Thanks.
Liteon dvd/rw
Thanks.
