Hi guys I have read the beginners guides which were really helpful so thanks for all the info from those... but I still need some advice on a Rad and Pump Combination.
This is my 1st water build so I am still wet behind the ears. (yes yes I know bad joke)
If I was to buy a Raystorm CPU Block (AMD) and used Koolance PMP450-S Pump top Including 12V Laing D5 Vario would a Phobya Xtreme NOVA 1080 Radiator be ok with that pump as I am a bit worried about the pressure. I know this is way overkill for just a CPU block but I want to be able to add to it later on as and when & be able to use it later when I get new hardware.. sort of trying to future proof myself.
I do also have a 120 triple rad but I am not sure what make it is I think it is a Koolance & I also have a 100ml Res with what I think is a EK multi option base.
My current hardware is a Phenom II X6 1090T overclocked to 4Ghz which I would like to try and push a little more if I can, it is currently being cooled by a Corsair H80, 16GB Corsair Dominator DDR3, Asus Crosshair IV Formula, HIS HD Radeon 5970 2GB GPU. All sitting currently in a NZXT Phantom case.
The thing I am mainly worried about is the pressure from the pump to the rad, any help / suggestions here would be great.
